Factors to Consider Before Making Your Purchase of a MIG Gun or TIG Torch
Andrew Pfaller
6s5a7721-v1
Learn about the different MIG gun and TIG torch types and how to select the best equipment for your job or project.
Air vs. water-cooled MIG guns and TIG torches
Torch and cable cooling play an important role in gas metal arc welding (MIG) or gas tungsten arc welding (TIG), and there are two cooling methods: air- or water-cooled systems. Cooling prevents the power cable, torch or gun and consumables from overheating.
For MIG and TIG welding, you need to consider similar factors and examine the following variables before choosing a system: cost, worksite location, amperage requirements, torch weight and operator comfort.
Water-and air-cooled torch basics
Air-cooled torches use the ambient air and shielding gas to dissipate excess heat. In addition, the power cable on an air-cooled torch contains more copper than the cable on a water-cooled torch to help prevent the cable insulation from melting or possibly burning. As a result, air-cooled torch cables are heavier and less flexible compared to water-cooled torch cables. However, air-cooled systems do not require an independent radiator cooling system and extra hoses that are associated with water-cooled systems. The simpler design of air-cooled systems make them easier to operate, assemble, maintain and transport.
Both air-cooled MIG guns and TIG torches are available in a variety of amperages for a multitude of applications. Air-cooled TIG torches are popular for applications equal to or less than 200 amps, but you can also find air-cooled TIG torches in 50- and 250-amp models. Air-cooled MIG guns are available in a wide range of amperages, between 150 and 600 amps.
The alternative to an air-cooled system is a water-cooled system. Water-cooled TIG torches or MIG guns require a radiator cooling system which circulates water through the head of the torch or gun and back over the power cable to dissipate heat from the torch or gun. However, water-cooled torch and gun cables are lighter and more flexible because the cable requires less copper compared to air-cooled systems.
Water-cooled MIG guns are typically available in 300- through 600-amp models, while water-cooled TIG torches are usually rated between 250 and 500 amps. Now that you know your options, review these factors to select the right system.
Cost
Cost is a major factor you should consider when deciding to purchase an air- or water-cooled TIG or MIG torch. Water-cooled torches and guns require a higher initial investment because you need a separate radiator cooling system in addition to the power source. Water-cooled TIG torches and MIG guns also require higher operating and maintenance costs. You must use specially treated coolant solution in the radiator cooling system rather than tap water, which could cause algae growth or scale (mineral buildup) on the internal torch surfaces and cable assembly. In addition, water leaks from hoses and the torch neck or heads may occur, which require immediate repair in order to prevent weld defects.
w-250-torch
a-150-torch
However, you may save money on consumable costs with a water-cooled system. Consumables typically last longer on water-cooled MIG guns and TIG torches because the radiator cooling system allows the tip, nozzle and/or diffusers to run cooler than with an air-cooled torch. This means less frequent consumable changeovers.
Operator comfort
Depending on your needs, the higher cost of a water-cooled MIG gun or TIG torch may be a viable investment. The flexible cable, lighter weight and smaller size of a water-cooled system provides more operator comfort. For example, the average 250-amp water-cooled TIG torch weighs approximately 3 ounces and measures about 6.5-inches in length, while a 150-amp air-cooled TIG torch weighs around 6 ounces and measures around 7.75-inches in length. If you are welding for an extended period of time, the greater weight of an air-cooled torch may increase operator fatigue and cause downtime.
Worksite location
When choosing air- or water-cooled MIG or TIG torches, also consider the location of the work. Is the application in the shop or in the field? Air-cooled MIG guns and TIG torches are more practical for outdoor worksites because they require fewer parts, which simplifies transport, set-up procedures and parts management.
On the other hand, water-cooled MIG guns and TIG torches are better suited to use in the shop. Water-cooled guns and torches are available in higher and lower amp options but require a separate cooling system. The water-cooling system and the extra hoses make these torches and guns less portable.
Duty cycle
Another major consideration in choosing an air- or water-cooled torch or gun is duty cycle. Duty cycle is defined as the percentage of time in a 10-minute period that the torch can be operated at a specific output without overloading. For example, to weld 16 gauge mild steel, you need at least 160 amps with 100% CO2 shielding gas. If a given torch is rated at 150 amps and you operate it at a 160-amp output, duty cycle decreases approximately 20%. Running a MIG gun or TIG torch beyond its rated output is not necessarily harder on the gun, but it may cause the torch handle and cable assembly to heat up much faster, which leads to downtime.
If the application you are working on calls for amperages higher than what the gun or torch is rated, Purchase a higher amperage gun or torch that can operate at a higher duty cycle. Both air- and water-cooled MIG guns are available up to 600 amps. On high amperage MIG applications (450 through 600 amps), the decision to use a water- or air-cooled gun depends on operator preference and cost. For TIG applications, use a water-cooled torch for jobs that are 300 amps or greater in the shop. However, for field applications, some manufacturers also offer 300-amp air-cooled TIG torches.
Balance Cost, Comfort and Welding Application Needs
Both air- and water-cooled TIG torches and MIG guns perform well and produce similar performance when used correctly. Torches and hoses on water-cooled systems are lighter and more flexible for greater operator comfort. Air-cooled torches can meet the demands of most industrial MIG and TIG applications while still providing the same performance at a fraction of the operating and maintenance costs, but they do add weight. Cost, welding location and comfort will determine the best solution for you.
