4 Ways To Reduce Welder Training Time in Manufacturing
insight-centerpoint-application-welding_feature
How much time does your operation spend on training? These tips can help you get new welders into production faster.
Training new welders faster
Many welding environments are changing as the industry evolves. Furthermore, improving productivity and getting new welders up to speed are big issues for many operations. How much time does your operation spend on welder training?
When welders are inexperienced or not properly trained, it can result in slower production, rework, more scrap and other costs. While proper training is important, is there a way for manufacturers to reduce the time spent on it?
Tip #1: Get help from new technologies
Machines that are difficult to set up and adjust usually require additional training. However, some of today’s welding power sources remove complexity and are designed to make setup and parameter selection easy. With preset parameters and other intuitive setup options, it’s easier and faster for welders of all skill levels to choose optimal parameters for producing quality welds.
One such example is EZ-Set technology. Available on Miller® Deltaweld® systems, this technology simplifies parameter setup based on material thickness. This removes complexity and reduces welder training time.
Tip #2: Follow the data
If rework and missed welds are problems in your operation, analyzing weld data can help. A weld data monitoring system can track weld quality within individual cells. This technology may be configured to monitor many types of weld parameters and to catch and contain weld defects before parts leave the weld cell. This can significantly reduce costly downstream work. The Insight Centerpoint™ solution helps reduce training time by guiding welders through the weld sequence in real time using visualizations of the part. Embedded videos, images, audio and other file types can give welders clear, complete guidance in the fabrication process. The system can also alert welders if a weld is missed or is outside of acceptable parameters, allowing it to be corrected cost-effectively.
Tip #3: Think about a welding process change
Switching to a different process can offer many benefits in a manufacturing operation. The Accu-Pulse™ process provides a 28% wider operating window and a more forgiving arc, compensating for variations in operator technique. Consequently, this helps welders of any skill level get into production quicker.
Tip #4: Reconsider the filler metal
Welders must be able to read their puddle fluidity and bead size to determine if they are overwelding or underwelding. Knowing that the puddle is flowing and wetting into the base metal is critical to laying down a good weld. Part of this is experience and technique, but filler metal also plays a role. Some filler metals are more forgiving than others. Switching to a different filler metal — such as a metal-cored wire — may provide a more fluid puddle that wets in well and is easier to use. A change may also deliver a cleaner metal transfer with less spatter.
Faster welder training
Whether your operation has an in-house training program for new welders, or you are putting welders directly into production so they can learn as they go, finding ways to make training more efficient can deliver significant time and cost savings. Investing in new solutions or making changes in the welding operation can shorten training time — and help welders of all skill levels produce high-quality welds.
